CPU 120mm fan grills, looking for quality, great flow, decent price?
RAAM
202
90
Love my H4 H20 280mm AIO build except when I put the panels on, noise increases dramatically and air flow decreases due to resistance.
Considering cutting out sections where fans are located, blocking off sections without since incoming air will all be filtered but doing so is not easy to figure out a nice pattern nor easy to do the work and make it look good.
I will try doing so but in case I mess things up and want to have grills I can use instead. I will be using either 3 or 4 120mm grills.
Let me know if you know of any nice ones, prefer sq shape and really like honeycomb designs the best.
Rick
