Hi Guys,
I'm new here, as a user at least, but i have been passing by this forum multiple times the last month while i have been sketching on my ideas for my first self-build desktop.
I am fairly set on using somewhat regular components - So ITX board, SFX PSU and ITX size GPU.
Looking at existing cases, i see that many are depended on side intake of air, which i feel is an annoying limitation to the aesthetics, the orientation of the case and lastly my own ability to make it with common tools.
After testing many many version of internal layout in CAD, i feel fairly confident in the latest iteration with GPU directly into the PCI-e and PSU next to the motherboard. For a long time my PSU was above the CPU heatsink, but i felt the Noctua L9i would be bad for internal airflow.
So as you can see in my sceenshots, i have made lots of room for a proper CPU cooler. But now comes the puzzle. The Noctua NH-U9S would be my logical choice - however the NH-L12s has a higher TDP for some reason. Same goes for the NH-C14s - Somehow that is worse than the L12s?
Which one would you guys recommend?
An as you can see in my capture, i am also playing with the idea of removing the fan from the heat-sink. Does anybody have any experience with performance when blowing air at the heatsink from a distance compared to attached directly to the heat sink?
I dont know if fabric will allow for a suitable airflow, but i am considering it for both aesthetics and to work somewhat like a dust-filter. The front IO i hope to keep minimal with just a headphone jack and a single USB port. The idealist in me calls for a usb-c, but quite frankly the only usb C thing i have is a bluetooth speaker. The last part of the triangle is supposed to be the on/off button. All this requires that i cut into the fan-frame, but it clears the blades easily.
With all the positive pressure from the front fans, i'm not expecting the need for a rear exhaust. However it may be its preferable for less noise (instead of front fans...)
This view also shows why i land all the way up on 11 liters. I have given the case som extra space in the back to route the cables to be less visible from the side. (The internals will most likely be black/metal, but is just white in my render because they do not have a material...)
Internal layout. Front: 2x 140mm fans. GPU: Most likely a RTX 2060, maybe 2070. Depending on which cooling layout i can find which fits the best. CPU: i5 9600K or i7 9700K. RAM: What ever is reasonable, 2x16GB - Most likely Corsair vengeance. PSU: Corsair SF600 or SF450 (depending on the GPU/CPU config). Motherboard: Z390 something. Depending on layout. And to be honest, probably depending on which one has a nice layout on the backside with a nice IO shield.
Just a small extra test with the design in a more traditional enclosure. I cant make up my mind which material to build it from. I think it could be cool in acylic too, but a bit too flashy for my desk in the long run.
Other material suggestions are very welcome!
