Zotac 1080ti SHIFT bracket (DXF)
Other Zotac 1080ti SHIFT bracket (DXF) NFC 1070ti and 1080ti SHIFT 2020
CAD for PCIE Bracket replacement creation for the Zotac 1080ti mini.
This bracket shifts the Zotac 1080ti mini and Zotac 1070ti mini toward the motherboard in the S4 MINI to allow clearance for the HDPLEX 400AC, enabling a "brickless" build.
This can be modified to invert the gpu 180 degrees if for some reason you want to do that...
Special thanks to Tacients for getting me to actually get this done, and for ordering the prototypes and testing it in her rig.
You can get it made at https://sendcutsend.com/ and I have a special coupon for you: NFC15SCS
Reactions: Curiosity and deeps
Author
Josh | NFC
Downloads
131
Views
4,604
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Josh | NFC
Latest updates
  1. 1070ti Mini and 1080ti Shift Bracket 2020 Update
    These cards are still being used in the MINI and I wanted to make the file cleaner. You can use...
