Resource icon
Other S4 MINI - Official template for WRAP 2017-06-16
This is the official NFC-SYSTEMS S4 MINI template for the 3M Controltac vinyl wrap system.
You can use this to design your own custom wrap to have professionally printed on matte or gloss material. For pricing and details through NFC-SYSTEMS please visit my shop.
Please use this template to customize your MINI however you see fit. Feel free to use it to get a wrap through another vendor, but I really appreciate your business!
This template can NOT be used to create replacement side panels for the S4 MINI. That is a different file which will be made available.
A major shoutout to Trevor from Buddha Brothers for helping me get the dxf perfect and for coming up with some crazy designs to show off the print quality which is outstanding!
Consider uploading your design and sharing in the S4 MINI thread so other users can have access to high quality patterns.
Check out my other resources for S4 MINI customization on this forum.
Author
Josh | NFC
Downloads
152
Views
3,294
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Josh | NFC
