CAD for PCIE Bracket replacement creation for the Zotac 1080ti mini.
This bracket shifts the Zotac 1080ti mini and Zotac 1070ti mini toward the motherboard in the S4 MINI to allow clearance for the HDPLEX 400AC, enabling a "brickless" build.
This can be modified to invert the gpu 180 degrees if for some reason you want to do that...
Special thanks to Tacients for getting me to actually get this done, and for ordering the prototypes and testing it in her rig.
You can get it made at https://sendcutsend.com/ and I have a special coupon for you: NFC15SCS
