I made this mockup file to make it easy for me and everyone else to visualize what their S4 Mini Wrap designs will look like.
I set up the file to use the same Template file that @Josh | NFC kindly provided us so if you have a design already made you can just place it inside the appropriate smart object and the mockup should work perfectly.
I am working on other views of the case as I have time so this resource will be updated to include them all in a Zip file as I add new ones. I made another view/version so now it is a .zip file If that is a problem for anyone just let me know!
If you run into any issues with the file please let me know and I will do my best to fix them for you! *User error not included
Here are screenshots of the available view(s) so you know what you can do:
(Credit for the photo I based this on to @MODZERO)
More to come...
More to come...
