REVOCCASES-RCC-BIG560-DIY Edition
This is the DIY-friendly edition of my RCC-BIG560 Case. It does not require any bending tools. All you need is access to a Laser Cutter or CNC Router to cut the panels and some tools for tapping M3/M4 threads.
Free to use for Personal Projects only - Commercial use prohibited!
A "BIG560 DIY Starter Set" w/o panels can be found here:
- All panels can be manufactured by laser cutting or on a CNC router out of 2mm Aluminum or Acrylic
- Standoffs required: M3x10, M3x7
- Screws required: M3x5, M4x8, CS M3x6
- If you don't have access to a laser cutter or CNC, I can also make you the panels
REVOCCASES - Revolutionary Small Form Factor Computer Cases
Discover our Custom Designed and Hand Crafted Small Form Factor ITX Computer Cases
shop.revoccases.com
