Resource icon
.STEP HDPLEX 200W AC-DC PCI Card Mount 4
This PCI Card Mount concept would allow mounting the HDPLEX 200W AC-DC in the Lone Industries L5, or other cases with 40mm clearance. Redesigned into a 3D printable part. ABS filament recommended due to higher heat tolerance.
Disclaimer: I'm not responsible if this fries your computer. I do not know if there's any potential issues sticking plastic into your PCI slot.
Author
Lone
Downloads
24
Views
2,078
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Lone
Latest updates
  1. Revision 4
    Added SketchUp file.
  2. Revision 3
    Redesigned into a 3D printable file. I have not printed this yet. ABS filament recommended due...
  3. Revision 2
    Just cleaning up the model, and added a locking tab.
