(Another) Custom PSU bracket for FormD T1
.STEP (Another) Custom PSU bracket for FormD T1 2023-09-01
Designed to be CNC machined. Lowers PSU position by 4mm (so that it's closer to the top/bottom panel). Check if you have enough clearance on the PSU power plug before use.
There are two versions depending on whether your T1 front panel has (v2.0) or does not have (v2.1 official) a slot. The only difference is whether the bracket has a protrusion intended to be inserted into that slot.
If using the bracket with a protrusion, the spine position may be limited to ~2+ slot mode. Check before use.
Author
stanleyguan
Downloads
29
Views
1,792
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from stanleyguan
