Prototype Neutrino : a 4L case dedicated to thin mini-ITX with discrete GPU
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Nice !! Can't wait to see that :)
I've experimented quite a bit with those flat heatpipes.
They work pretty well in my HTPC, replacing copper heatpipes :
Or even paired with a Zalman GPU Cooler :)
Reactions: BaK
BaK
934
934
Lol all those builds of yours!
The two above are awesome!
Once in the prototyping stage I will for sure have questions about flat heatpipes. I will get back to you then. :p
Reactions: aquelito
BaK
934
934
Heh was about to start the thread right now but realized I forgot a render at home :\
This is going to be for later tonight, finally...
Well okay... here comes a little hint especially for you!
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Woah !
One for the CPU with a 90° bend pipe, one for the GPU directly screwed ?
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
It's filling-loop time !
This is how it's done without a reservoir : using a syringe to completely fill the loop, with a lower hose diameter to let the air escape.
It's very quick and usually I get ride of most of the bubbles.
Considering that the waterblock, radiator, pump and pump top have been modified, I'm pretty glad the leak test was a success !
This is my prototype powered with a Hdplex 160W + Dynamo.
The GPU is a 1050 Ti KalmX, run passively to better evaluate the pump noise.
The pump run @ 1844 RPM @ 7V for my tests. I can definitely hear it.
The Noctua Fan remains silent until 60%.
After 30 min of XTU Bench, the i7 3920XM stabilizes around 70°C, 72° on the hottest core, running at 3590 Mhz:
https://hwbot.org/submission/4096788_aquelito_xtu_core_i7_3920xm_735_marks
This is not bad considerign that the waterblock doesn't even have a maze but it could be definitely improved.
Next steps : try a Koolance block instead and ask to the motherboard OEM if they can provide a BIOS allowing to OC the 3920XM.
https://koolance.com/index.php?route=product/product&product_id=87
Windfall
2,117
1,583
EPIC Update! Question. Will you sell this case?
Reactions: aquelito
BaK
934
934
And the guy risks is much loved hardware in leak testing with Sopalin (I think that's how you call household paper in France)! Don't lie, I see some left on top of the rad in the 2nd pic! ;)
Plus, you were certainly expecting a leak as you moved your prototype into the kitchen to fill the loop! (I see a toothbrush but the other tools must be for cooking)
Come on....! lol
You should invest in some cheap parts and air leak test safely instead:
https://www.overclock.net/forum/61-...-how-correctly-leak-test-your-loop-101-a.html
Apart from that, this tiny build is getting itself together very nicely, congrats! :thumb:
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
@Windfall
I've got one prototype left :) I'm not sure I will make a real production.
@BaK
Ahah ! With such a simple loop, there was no real risk here ;) but yes, I should try that method next time.
