Prototype Neutrino : a 4L case dedicated to thin mini-ITX with discrete GPU
AlexTzone
I design minimalistic – but not boring – PC stuff
THOR ZONE
1,298
2,752
thor-zone.com
Hey man, really like the development of your case! Keep at it :thumb:
I hope you don't mind me asking, what are those corner blocks/brackets called? (the ones that function similar to an L-bracket).
Best,
Alex
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
@AlexTzone : you mean the 12x12 threaded cubes I used on the previous proto ?
@Windfall : the case is to be completed with 3 complementary 2 mm aluminium panels : IO, front and top panels :) each of them being screwed to the clinch nuts in the main body.
Reactions: AlexTzone
AlexTzone
THOR ZONE
1,298
2,752
thor-zone.com
Ah thanks a lot for that, unbelievable how hard it can be to find simple things sometimes! :)
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Look what we've got here ! Just an other thin mini-ITX board with a full size X16 slot (X16 electrical).
This one is a LGA1151 from DFI, featuring a Q170 chipset.
Also received this Xbox 360 waterblock from Alphacool. Only 13mm high. Gives me some idea of a fully watercooled build with an external rad :)
BTW, the case prototype has been made 1 mm too narrow.
As a direct consequence, the radiator / pump combo does not fit anymore.
I will have to unsolder the soldered fitting and trim it a little bit.
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
@rfarmer : I just positionned the block over the socket.
Mounting holes are 58,5 x 58,5 mm (which is pretty convenient for Nvidia GPU).
I'll need to make a custom bracket but that's pretty easy.
I'll also need to add a 2 mm copepr piece between the IHS and the waterblock, to avoid the upper so-dimm slot.
This copper piece could also be extended to cover the chipset and VRM around the socket :)
Reactions: rfarmer and owliwar
Goatee
738
1,512
Is the board a SD106-Q170? I like the look of it but are they Msata ports rather than M.2?
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Yes it is !
Snapped it for 72€ on eBay. Retail price in France : 421€ ahah !
BTW, I took 15 min with a mini welding torch to unmod my dual 60mm radiator.
I removed the fillport that was added to trim it by a few mm.
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Not much progress here. Waiting for a 3920XM that I found for a good price on eBay.
I will also replace the dual 60 radiator by a single 80.
Fitting the pump in the case prototype was real tight and the radiator was recycling the hot air exhausted by the GPU.
A friend of mine already modified the rad for me to add a fillport, same as for the dual 60.
Tight fit but my 3D model happens to be fairly accurate :)
Next steps :
- change the waterblock for a Koolance GPU-180-H06 to cool the 3920XM,
- modify the pump top to add an other inlet,
- drill a set of holes into the case.
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
After modding the radiator to add a fillport, I've modified the DC-LT pump plexi top, to add an other inlet.
I also started drilling the exhaust holes into the case but this is not the funniest part...
Windfall
2,117
1,583
Looks great!
Link1712
Awesome tiny setup you got there!
I was wondering if you had to do some custom circuitry for the switch or if it works like any other ordinary switch?
All in all, great job :thumb:
aquelito
Piccolo PC
Feb 16, 2016
952
1,123
Reactions: Link1712
BaK
934
934
Another modded radiator, nice! :thumb:
Good luck with the holes drilling, hard stuff not to go off center!
While rereading your thread form start, I noticed that you had a trial with air cooling and flat heatpipe that I missed before.
So I have to quote you
Great minds think alike ;)
You will see why very soon ;)
Reactions: aquelito
