Motherboard ECC SODIMM in DeskMini A300/X300
gagarin61
Has anyone attempted to use ECC SODIMMs in the ASRock DeskMini A300 or X300? Does ECC work? Does the memory work in the A300/X300 at all? Does it boot?
I've ordered a Ryzen 7 PRO 4750G, 64GB (2x 32GB) Micron DDR4 ECC SODIMM 3200Mhz and a DeskMini X300, hoping it'll play together.
yuusou
116
72
Best will be to check in the BIOS as it's mostly the motherboard that decides whether ECC is supported or not.
ratundtat
78
Very good question. I do not know this, too. I was asking myself the same.
On Asrock-website for A300:
Memory - Supports 2 x SO-DIMM DDR4, Max. 64GB (non-ECC)
It is means ALL RAM without just non-ECC or if connected the maximum of 64GB?
Perhaps "(non-ECC only)" or "until 32GB ECC support" is more meaningful!?!?
The question is, is the mainboard compatible for ECC?
So, A300 has got full 72-Bit (64Bit Data + 8Bit ECC) and UEFI-Support, too?
The CPU Pro-Series can control ECC-RAM.
And X300? I see no differences of A300, just UEFI-Firmware. And that USB 3.1 gen1 is called USB 3.2 gen1, now. <-- it is the same technic, speed, port!
In BIOS hmmm that is no BIOS, it is UEFI... It could written "ECC", but take care. The original motherboard could have ECC, but A300/X300 is just a hmmmm lower revision from a PC edition. And some Linux and Windows users had troubleshooting with Windows and lagging YT-Video and CMOS crash because Crucial P1-NVME + Linux Mint, because the UEFI-Firmware (P3.60[final]) of the Deskminis is not perfect. As like as, the newest final A300-firmware (P3.70) is with older AGESA as the previous BETA versions (P3.60K).
For renoir CPU, you will need: AGESA V2 1002 !
That is:
A300 - P3.60S (not official)
X300 - 1.46 ( I do not have X300, perhaps 1.40 is ok!)
736
If I had ECC SODIMMs I’d test it for you. I’ve got an X300 and 4650G already. When my X300-ITX arrives I’ll see if I can get my ECC UDIMMs working on that.
736
FWIW @gagarin61 - for my server I ended up getting a cheap Asus MATX ”Tuf Gaming” board that came with ECC support listed on the spec sheet.
