CPU Asrock DeskMeet X300 / RAM Mhz speed
RZ2019
21
My first ever DIY PC was the Asrock DeskMini X300 which I love so much. I just gave it to my son and have build the Asrock DeskMeet. So far it is great!
It is with AMD Ryzen 5 5600G and Corsair 32GB 3200 RAM. In the BIOS by default AUTO it opens as 2133Mhz. The BIOS version is 1.4. Is it safe to tweak it to right speed 3200Mhz? Will work OK or crash? Is there any danger in doing so? Sould I change also the voltage-
Will I feel big difference between the Mhz?
Arboreal
811
810
I don't know your BIOS version, but if it allows you to run the ram at 3200, go for 3200.
All APUs need to be run with the fastest RAM possible, otherwise you'll be losing performance capability.
If the RAM is 3200 you shouldn't need to overvolt, assuming that option is available.
My DM A300 ran 2133 RAM happily at 2666 until I bought 3200
Yes, it makes a difference
Reactions: Solo
Solo
863
1,438
I have 64GB (two 2x16 3200MHz sets) in mine and was able to set the XMP profile and forget about it. So far I have been fine.
