Completed Custom_MOD SFX 9.3L
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
Specs:
- CASE -- PHOTO ALBUM
- Volume: 9.3L (265x220x160mm)
- Weight 1.5kg
- Production: ESI METAL factory (video), swiss solutions «Bystronic»
- Material: 1.5mm Aluminium, Powder Coating
- GPU: length <230mm, height <135mm
- CPU Cooler: up to 60mm
- Storage: 3x SSD/HDD 2.5"
- PSU: SFX / SFX-L
- PCIe riser: LiHeat 200mm B.type
- Сooling: 1x120mm fan front
WATERCOOLING:
120mm Radiators up to 130mm wide, up to 155mm tall. (bequiet SILENT LOOP | 120mm)
Thickness of the radiator + fan should not exceed 60mm
grumpyrobin
260
190
I like the design, and I was really hoping that you would make a bigger case.
so it is kind of akward to ask this........
if the GPU is at a right angle to the motherboard....woudln't it be better to just have a standard layout so you can have 130mm cpu cooler clearance?
or is the point of this layout that by saccrificing the cpu height you make more room for the PSU/storage while keeping everything compact?
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
Many options considered. It seems this is the most compact. Plus has not seen such a layout.:)
Reactions: Jonny727272
W1NN1NG
616
532
pretty sure the point is for an AiO watercooler tbh or that as such as a fractal kelvin etc
Revenant
Revenant Tech
1,681
2,720
NICE.. excellent placement of the GPU on top. Should allow a 1080ti mini. I like the hard drive mounts. Perhaps you can fit a 3.5 inch drive in there. I would want to close off the front of the case though to keep noise to a minimum though.
CC Ricers
2,233
2,556
If I didn't know any better, you could probably fit a custom water cooled loop in there and have the GPU waterblock show off with a clear top panel!
psycho88
56
28
it's nice, but from the position of the GPU, i think i can't use full cover waterblock for my GPU,
i Like the GPU & motherboard position/orientation just like case Flex mini you've made before,
plus with mobo&GPU position in case flex mini, we can show off the GPU & motherboard (with acrylic panels)
sorry for my RIP english
