Concept cases "TX aio" produced by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
case TX1 aio 18L rev.1.0 prototype
Specs:
- Volume: 18L (320mm x 345mm x 165mm)
- Material: Steel frame (1mm), aluminum covers (1.5mm), Powder Coating
- MB: ATX
- GPU: length <310mm, height <130mm
- CPU Cooler: up to 50mm
- Storage: HDD: 2 x 3.5"
- PSU: ATX
- AIO: radiator 315x30x143mm (FANs: 2x140x25mm)
- FANs: 1x120x15mm slim
- PCIe riser: LiHeat 250mm D.type
case TX2 aio 12L rev.1.0 prototype
Specs:
- Volume: 11.9L (280mm x 305mm x 140mm)
- MB: mATX (245 x 245mm)
- GPU: length <275mm, height <115mm
- Storage: HDD: 1 x 3.5"
- PSU: SFX / SFX-L
- AIO: radiator 275x30x123mm (FANs: 2x120x25mm)
- PCIe riser: LiHeat 200mm D.type
Pkhairnar6
I love the design but what would be the point of using an ATX mobo if you can't use other PCie slots? Maybe someone can shed light on my lack of knowledge or ignorance.
HDD, more RAM slots are the only potential advantages I can think of honestly.
5,858
4,914
Board choice is the main reason: there are very few good mATX boards these days, while ATX has the pick of the litter. On the other hand, many people just use one GPU in ATX anyway, it would allow a lot of people to just migrate their 40+L builds to this case.
2,201
2,225
More m.2 slots? Added RAM slots aren't a bad idea with current RAM prices either. Also, more boards to choose from, and generally lower prices? There are plenty of <$100 ATX boards out there with decent specs, but not many ITX or mATX ones.
2,201
2,225
Why is the radiator on the side, instead of the front?
To not limit GPU length? Also, the PSU needs to go somehwere, so this looks like a very space-efficient design - if you moved the aio to the front, the PSU would need to overhang the motherboard to not increase case size, which is very impractical. Essentially a dual-chamber design with one chamber for mobo+gpu, and one for the AIO and PSU, and each of them no larger than what is required for the components to fit.
Reactions: chyll2 and sergiiua
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
very accurately said.
AccountIsTaken
What would be the performance if you swapped the perforated acrylic panel on the side with a tempered glass panel. I can see a 120mm fan mount on the bottom. Would you be able to use a thin 120mm fan to provide the air for the gpu?
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
I think the air will not be enough. it is necessary to test
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
Specs:
- PSU: SFX / SFX-L
yensteel
32
30
Wow, I really love that design! There's no compromises at all, except for lack of a second GPU capability, which isn't too important for me.
SirJack
95
59
I am throwing money at the screen and nothing is happening...
Do you think it is possible to fit a second 120 aio for hybrid GPUs in the drive bay?
