Production case SXM 6.3L by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
Case SXM lm 6.3L rev.4​
Case SXM lm 6.3L rev.4 received a number of changes. We swapped the motherboard and video card. Now the motherboard is installed on the left, and the video card is on the right in an inverted state.
It was designed for powerful computers with Core i7 processors and GeForce RTX 3060 and 3060ti graphics cards.
We also make a special case model SXM 6.3L Liquid Cooling, for powerful work computers without a video card. In such cases, instead of a video card, you can install a 140 mm radiator for liquid cooling of the CPU.
  • Size: 260mm x 130mm x 187mm
  • Material: aluminium (1,5 mm); Steel (1mm)
  • MB: mini-ITX (170x170mm)
  • GPU: dual slot >42mm, long to 183mm
  • Cooler: up to 70mm
  • FAN: 1x120x15mm slim
  • Storage: 2 x SSD 2.5"
  • PSU: SFX / SFX-L*
  • *When installing the SFX-L PSU, it is not possible to install a 2.5 "data storage device.
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
Any chance these will be produced again? I did not see any in stock.
It is hard to say. I'm trying to understand the demand for models and understand which ones to produce next and which ones to leave in the past. Now is a very difficult time, I can not afford to do all the models as before. Perhaps I will leave three or five of the most popular and I will deal with them in parallel while working as a builder. My business is no longer able to feed me, I am looking for additional ways to earn money.
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
And here is the new revision of the SXM 6.3L case! Now the motherboard is not upside down and even minor improvements.
Case SXM 6.3L: 260 х 187 х 130mm
Riser: ADT-Link PCIe 4.0 ITX 17cm
MB: mini-ITX
Cooler: >70mm
GPU: 2 slot >183mm
SSD/HDD: 2 x 2.5"
PSU: SFX/SFX-L
FANs: 1x slim 120mm
sergiiua
CustomMOD
Jan 11, 2017
1,136
2,027
www.custom-mod.com
New model SXM2 7.3L for mini video cards up to 212mm long.
◉SPECIFICATIONS:
Size: 260mm x 130mm x 215mm
Material: Aluminum and Steel (1.5mm)
Weight: 1.4kg
Powder paint: Black or other color according to the RAL catalog
◉COMPATIBILITY:
GPU: up to 212mm long
two slots (max 42mm)
Cooler: up to 70mm high
Storage: 1 x SSD/HDD 2.5"
PCI-e riser: 16x16
PSU: SFX / SFX-L
dragon325
When will the SXM2 7.3L be avail and what is the pricing? Checked the website only shows the older SXM 6.3 model.
I'd be interested in this newer version that can fit a longer GPU in white color
