Hi all. This case is similar to Inwin Chopin, but smaller (~1.5 liters reduce). So i call Mini Chopin ☺
Case: ZongShi zs-D1
Dimensions: 186x189x80mm = 2.8 liters
Installed weight: 1.7kg
Mainboard: Asus Z97I-Plus
CPU: i5-5675c w/Iris Pro Graphics 6200
Memory: Crucial Ballistix Tactical LP 2x8GB
SSD: Samsung SM951 256GB
SSD: Lexar 512GB
Power: General Electric CLP0212 200W + PicoBox DC-ATX 160W (sold with case)
Notes:
- Some mainboard not support. ZongShi's recommend Gigabyte B450 mainboard.
- Power really good, comfortable for iGPU/APU, no break down when stress.
- Easy to install, except SSD. Screw holes under the mainboard, to install/remove you have to remove mainboard first.
- Support 2 SSDs.
- CPU cooler under 50mm (AMD Wraith Stealth can fit with fan shroud removed)
- Memory under 53mm (I try Dominator 55mm but not fit)
- Have a USB 3.0 port in front.
- C6 power inlet, like Chopin ?
Case: ZongShi zs-D1
SSD: Lexar 512GB
Notes:
- Support 2 SSDs.
