ZOTAC has finally released more info on their EN1070 successor. It’s got a Intel 6 core / 12 thread CPU that boosts up to 4.5GHZ, and RTX 2070. Slots include 1 NVME, 1 2.5 SATA, and one Optane slot, which should just be NVME. So maybe 2 NVMEs depending on specs.
The most interesting bit is that they’re including a 330 watt power brick. The EN1070 brick was only 180 watts.
The unit has a HDMI 2.0 port, but with recent driver updates, we’ve seen Nvidia unlock HDMI 2.1 with Variable Refresh Rate support (Gsync). This might be a good living room PC.
No pricing but I’m estimating one arm and at least a leg up to the knee. (See Edit 2)
I have an EN1070. Typically it stabilizes at 2.5 GHZ CPU and 1.5GHZ on the GTX 1070. Its biggest bottle neck though is the CPU which is an Intel 4 Core/4 thread 6400T. If the specs for the EN72070V are legit, then I can easily see this system putting out 80FPS 1440P Ultra in Battlefield V (no ray tracing), and being a great VR rig.
EDIT: The unit is 2.65L in volume.
EDIT 2: In the Zotac Facebook page, a MOD just stated it will cost between $1100 and $1500 (barebones) depending on the region. Less than expected.
MAGNUS EN72070V (Barebone) | ZOTAC
<p>MAGNUS EN72070V is the ultimate Mini Creator PC. Built for creators and hardware enthusiasts, it's empowered by a 9th Gen Intel Core™ i7 processor, NVIDIA GeForce RTX™ graphics and premium connectivity. Re-engineered with breathability and striking the perfect balance between power and...
www.zotac.com
