Resource icon
GPU Zotac 2070 Super PCIE Shift Bracket (Testing) 0.9.1
Steelmint
Steelmint submitted a new resource:
Zotac 2070 Super PCIE Shift Bracket (Untested) - Modified vesion of the 1080ti shift bracket to fit the Zotac 2070 super mini.
This is an UNTESTED modified version of NFC | Joshs 1080ti bracket to fit the 2070 super. It may also fit on the 2060 Super.
This needs taping at the small folding flanges with M3.
I will update this once someone tests it and makes sure it works.
Contents:
.step
.dwg
.dxf
of the bracket, 1x with Square vents and one time with triangular vents.
Vaderator
67
155
Huh, I thought that 1080 bracket would work with the 2070s. I just ordered a 2070s thinking I'd get better performance due to thermals. Are the mounting points different?
Steelmint
Slightl differences but not a lot. I just made this as it doesnt have the DVI slot and should work with the 2070S.
