Planning on using two MW RPS-200-12-C for a water cooling build, not the most compact at about 9~10L with 280 radiator support. The power supplies will sit under the radiator fans and be cooled that way.
Layout:
1x RPS-200 +12V -> picoPSU -> board + CPU
2x ground -12V -> picoPSU + GPU
1x RPS-200 +12V -> GPU
Is it a good idea to have the ground linked together or is better to keep them separate? And will the motherboard supply the GPU with power through the PCI-e socket?
My concern is for any conflicts between the two 12V supplies, technically a two rail PSU but with separate ground.
Is this achievable or I should just look for a more powerful 12V supply?
Layout:
