One last thing I need to do to finish my Xbox-build is to fix the power-button LED, as I could not get the stock LEDs to work without short circuiting the board --> causes the entire PC to just shut off. The PCB to which the power button and LEDs are soldered seem to be made so that all circuits are connected. I get the same issue if I try to convert the smaller button as a reset button.
So my question is simple; what kind of LEDs can I use (Voltage, Ampere) as I would just hook them up straight to the the power pins on the motherboard next to the on/off switch on the motherboard.
