So, what the title says, I'm trying to essentially take a M.2 M key drive and connect it via usb so that I may clone the drive.
Its my current windows drive, and I've been having issues with it not being very stable, and simply wish to buy a different NVME drive to replace it. I've already RMA'd it before, and simply do not wish to bother with trying to RMA it again, as that would require the hassle of cloning it onto a spare 3.5" drive, then sending it in, waiting another week for a drive from a company that I no longer trust with using as a main drive. Then cloning the drive back on to the new one, and most likely have a similar issue crop up yet again.
At first, I looked at the M.2 enclosures, but they only support B or B+M. They do not support M Key drives.
So, I got a great idea, having recalled the external pcie boards that have become popular with miners, I thought of using a M.2 adapter in conjunction, but I noticed it only uses usb 3.0, so file transfers would be really slow.
I also thought of using a thunderbolt enclosure, but my PC currently only has usb 3.1 gen 2 ports(with the rest being gen 1), and no thunderbolt ports. In order for this to work, I would have to get a converter.
The last option would be to take out my spare B+M drive and since that port also supports M drives, use it, but it is somewhat of a pain to get out, as its buried under my onboard sound card which is on a riser itself. The main reason I don't want to do this is I would essentially not be able to use the old drive at all with this option.
Any suggestions?
Any suggestions?
