I'm building a SFF workstation to travel internationally with to events and workshops. This is my first desktop build in eight years and first SFF ever. I could use some quick advice on a few things.
I need two 10 GigE ports for the radio hardware that I use which ended up as the main design challenge for selecting parts. My approach is to use a case that will fit a dual slot GPU and an additional card and a motherboard that supports PCIe Bifurcation. My most common workloads are intensely multi-threaded so more cores is better than faster cores. The appearance of the PC isn't a key issue. I want to air cool because of possibly bringing the PC in carry-on and generally just nervousness about leaks during shipping/travel. My budget is flexible.
Current Part list:
Has anyone air-cooled a 105 W TDP CPU in an SM560 case, and if so, with what cooling setup and what sort of thermals under full utilization? It'd be nice to know if a hotter (more cores) CPU was an option.
Nvidia's passive aggressive stance towards OpenCL has largely sunk them for me unfortunately. I think I have to lean towards the AMD RX 5700 XT despite higher thermals and power consumption. It does look like people have had good success substantially undervolting it though. The Sapphire 5700 XT Pulse is 254 x 135 x 46.5mm. 0.5mm narrow enough (yikes), but 2mm too tall according to the SM560 measurements. @Sligerjack, any chance you can confirm my guess that I can just shift the IEC mounting plate up 2mm as needed without needing to go for the pigtail? Also, how's the screen printing of graphics on the case coming along?
Thanks for reading and for any advice you can give!
Current Part list:
Case: Sliger SM560 (vented sides)
Motherboard: Asrock X570 Gaming ITX/TB3
CPU: Ryzen 3700X or 3900 [65W TDP, not overclocking]
CPU Cooler: ID-COOLING IS-60
Memory: Corsair Vengeance LPX DDR4-3200
Video Card: Sapphire RX 5700 XT Pulse
Network Card: Mellanox ConnectX-4 Lx Dual 10 GigE SFP+
Power Supply: Corsair SF600 W 80+ Platinum SFX
Storage: 2x 2.5" SSDs
Case Fans: 4x Noctua NF-A12, all exhausting so the case runs negative pressure, otherwise bottom intake and top exhaust
M.2 Slot: PCIe Gen4 x4 NVMe drive or Aller Artix-7 FPGA board (future add on, thermal pads between card and case frame)
My main concern at the moment is actually whether SATA cables can even connect to the right angle motherboard headers since the PSU will be really close. @thewave1408 warned about this but I can't find a follow up with whether the low profile cables worked. I'm looking at getting some Silverstone CP11 Ultra Thin cables, but would love a little confidence that they'll fit.Has anyone air-cooled a 105 W TDP CPU in an SM560 case, and if so, with what cooling setup and what sort of thermals under full utilization? It'd be nice to know if a hotter (more cores) CPU was an option.
