If I use a Titan XP what space do I need between the motherboard and the enclosure wall?
HeroXLazer King of Cable Management Original poster Sep 11, 2016 707 476 Dec 19, 2016 #1 If I use a Titan XP what space do I need between the motherboard and the enclosure wall?
Kmpkt Innovation through Miniaturization KMPKT Feb 1, 2016 3,382 5,936 Dec 19, 2016 #2 I believe it is 6.35mm between back of motherboard and any other surface. I think this is what you're asking, isn't it?
HeroXLazer King of Cable Management Original poster Sep 11, 2016 707 476 Dec 19, 2016 #3 ilovelampshade said: I believe it is 6.35mm between back of motherboard and any other surface. I think this is what you're asking, isn't it? Click to expand... No, I meant to say how much clearance for a dual slot GPU between the motherboard and enclosure wall.
Phuncz Lord of the Boards SFFn Staff May 9, 2015 5,948 4,953 Dec 19, 2016 #4 Does this answer your question ? https://smallformfactor.net/forum/threads/airflow-questions.1064/#post-20949
HeroXLazer King of Cable Management Original poster Sep 11, 2016 707 476 Dec 19, 2016 #5 Phuncz said: Does this answer your question ? https://smallformfactor.net/forum/threads/airflow-questions.1064/#post-20949 Click to expand... No. I just don't know how much space is needed for a dual slot GPU.
Necere Shrink Ray Wielder NCASE Feb 22, 2015 1,720 3,284 Dec 19, 2016 #6 This help? Note this is only for a dual-slot, reference-height GPU (which the Titan XP is). Reactions: K888D
HeroXLazer King of Cable Management Original poster Sep 11, 2016 707 476 Dec 19, 2016 #7 Necere said: This help? Note this is only for a dual-slot, reference-height GPU (which the Titan XP is). Click to expand... Ya, so If I put 35 mm between motherboard and chassis end I'll be good?
Necere Shrink Ray Wielder NCASE Feb 22, 2015 1,720 3,284 Dec 19, 2016 #8 Yeah, as long as the case wall next to the GPU is ventilated.
HeroXLazer King of Cable Management Original poster Sep 11, 2016 707 476 Dec 19, 2016 #9 Necere said: Yeah, as long as the case wall next to the GPU is ventilated. Click to expand... K, I make vent holes
