UPDATE:
Thanks everyone for their help. I understand things now ?
So I'm in the process of buying PC parts for an SFF build.
I'm limited on space so I was planning on using a couple of M.2 drives and a 7mm 2.5" either SSD or HDD.
The board im gonna use (ROG Strix X470-I) says this:
Expansion Slot:
AMD Ryzen™ 2nd Generation/ Ryzen™ 1st Generation Processors:
1 x PCIe 3.0/2.0 x16 (x16 mode)
Storage:
1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (SATA & PCIE 3.0 x 4 mode)
1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (PCIE 3.0 x 4 mode)*1
*1 The M.2_2 slot shares with PCIE x16. When M.2_2 slot runs in PCIE mode, the PCIE x16 slot will run at x8 mode.
The m.2 drives i want to use are: WD_Black SN750 NVMe - Interface PCIe Gen3 8 Gb/s, up to 4 lanes.
the GPU i'll be using is the Radeon VII.
Will I face any problems/reduction in speed on the drives or GPU if I use both M.2 slots?, If so, Is there a way to use one slot as SATA so it doesnt take away the PCIE Lanes? Or if i'm using the bottom M.2_2 slot, that will happen regardless?
Thanks!
Expansion Slot:
Storage:
Thanks!
