Blimey, I go to work for a bit, and the replies have avalanched in!
Thanks all, I must now sit down and watch Josh's video, as I haven't seen it.
Can't believe I missed that super compact build by
@Thehack - good photos to see a piece PSU solution in action.
Even if the solution that
@Kmpkt has suggested is 'only' 25% smaller than an SFX, it will be more flexible as with an 'ATX plug' solution, you lose a lot of the PSU to mobo 'spaghetti'.
Also, I guess you can fit the AC-DC board somewhere where there's room and run a suitable DC cable to the second part of the system.
The space needed for the AC-DC board being 1/2 the size of an SFX PSU means that you have more choice of where it can go, as you may have more small spaces in the case than large ones.
At the moment, I'm messing round with trying to fit an SFX PSU into the front of an SG05 where the fan usually goes, but another project may also benefit from something smaller & more flexible than SFX.
Skull Canyon NUC; weeeeeeeeeeeell, I
like NUCs, but don't
need one. That SC is pretty extreme compared to one of the standard little cubes, and out of my budget.
My SFF requirements would really have to include something like GTX 1060 level graphics, which no current IGP can achieve.
Thanks again guys
