CPU Sliger S610 Case Fan Temp Testing Alpenfoehn Blackridge & Noctua L9x76
Mark13
179
228
I decided to do some temperature testing in the Sliger S610 case with - 13.3 liters volume.
This is very easy to do with all panels being mounted with pull-off ball studs.
From the pictures you will note the case is inverted as the Alpenfoehn Blackridge cooler only fits in one direction on the Aorus B550 MB and needs to be inverted so the the cooler's heatpipe "U" is not facing downwards. I noted this in an earlier posting referencing Noctua's guidance on correct heat pipe orientation.
Sliger makes this case inversion very easy as well as only the power button & 2 USB ports need to be remounted as one unit to the other side of the case.
In particular, I wanted to see the difference between various case fans setups with the Noctua L9x76 (the L9x65 with the A9x25 fan) and how much difference they would make, as from earlier testing in a smaller case I noted that additional case fans were necessary to properly cool other MB components.
All fans where set to read CPU Ryzen 5 3400G temp.
2 Temps were noted on the L9x76 for CPU: temperature after 11 minutes / max temperature. Temp sensor 1 was the slowest to cool down.
Actual temps in a 21C room:
Cooler​
Alpenfoehn Blackridge A12x15 & A9x14 Dual Downdraft​
Noctua L9x76 (L9x65 w/ A9x25 Fan)​
Fan Configuration​
2 A12x15 Fans
Top Exhaust & Bottom Intake​
2 A12x15 Fans
1 A12x15 Side Intake only​
1 Scythe Kaze Flex Black 1500 Side Intake Only​
2 A12x15 Fans
Top Exhaust &
Bottom Intake
& SKFB 120 Side Intake​
3 A12x15 Fans
Top Exhaust, Bottom Intake& Side Intake​
2 A12x15 Fans
Top Exhaust & Bottom Intake & 92x14 Black Ridge Rear Exhaust Fan​
Temp Sensor 0​
40​
40​
43​
43​
41​
43​
41​
Temp Sensor 1​
43​
45​
47​
45​
43​
45​
44​
Temp Sensor 2 CPU​
67​
70/54​
71/55​
72/53​
70/51​
71/53​
70/55​
Temp Sensor 3 PCI​
21​
21​
21​
21​
21​
21​
21​
Temp Sensor 4​
40​
42​
44​
42​
41​
42​
42​
Temp Sensor 5​
39​
40​
42​
41​
40​
41​
40​
Pkg Temp​
69​
73​
74​
73​
73​
73​
72​
Wattage​
88.97​
88.76​
88.78​
88.63​
88.88​
88.65​
88.91​
NVMe Top​
41​
43​
45​
43​
42​
43​
47​
Comments​
Very Quiet​
Loud​
Reactions: scatterforce
