Completed SLATE-CASE AQ >>Status Update - Finalizing Order Fulfillments!
borys82
Thanks for the shipment to Poland, it's a joke that there is no such possibility and so I waited.
and what about this topic zero answer? You added, for example, Finland, which has 5.5 million people and Poland (38 million) lacks. I don't know what was your driving force
Reactions: TaylorChiller
borys82
when I ordered the Sliger Sm580 os for premiere, there was no problem with delivery to my country
kippenvel
The shipping is a bit steep to Europe. I also didn't see an option to order two tempered glass panels. When I'm paying this much for shipping, I would really like everything to be delivered at once. Any possibility to order with two glass panels?
robojim
254
222
I asked before and the issue is making more SKUs makes inventory management more difficult for mr Taylor. As for shipping to Europe, unfortunately with pandemic + the ukraine stuff, shipping will be expensive anywhere for a while.
6ixty9ine
23
23
Forgive me if it's already been asked, but does anyone know how big the passthrough at the back for the IO cables are? I need to stuff 4 DP cables and another 3 USB cables into that passthrough, and I'm not sure if it can... fit.
Gmoney
76
73
I dunno if this is the right case to try and squeeze 4 DP cables into especially since you might need right angle cables and one may interfere with the other beside it.
TaylorChiller
Super Magical Detailer
284
872
@borys82
TO clarify on your question. I selected certain countries because they are simply easier and less costly to ship to compared to others. If fact, it is more expensive to ship into Poland than it is Finland at the moment. I assume it has to do with the war. In general it is expensive to ship to Europe, because we do not have a warehouse there as we are starting this first run.
TaylorChiller
284
872
You are not the only one asking for this specific option. The reason we kept one perforated panel by default is because it needs to meet MOQ. However there are not too many people asking for dual glass panels so we may have an accommodation for this as we near May 15th
Reactions: N9neBreak3r
TaylorChiller
284
872
This will depend on your cable head sizes. If you can give me the dimensions for this I can check for you.
TaylorChiller
284
872
So the DP angles are Down angled. If all of your DP headers on your GPU are in one line, then it should fit, but we haven't tested 4.
