Hello everyone,
I'm new to the sff world and would appreciate any help getting started in the area.
I've just bought an NFC Skyreach 4 mini and plan on transferring the guts from my current mini ITX build into it, though was unsure of compatibility. The components are as follows:
* Asus Z270i Strix
* Intel i7 7700
* MSI Aero ITX GTX 1070
* HyperX Predator 2x8 DDR4 2666
* WD Black 500GB NVME SSD
I'm mainly wondering if there will be any issues physically fitting the gpu in, I've searched around but couldn't find anyone with the same one in a S4. It has the 8 pin power connector on the side instead of the top so I thought that might interfere with going brickless?
The second thing I'm looking for confirmation on is that I've chosen the correct power supply. I've gone and ordered a HDPlex 400W AC-DC and a Dell 330W power brick - as far as I was able to tell that will both fit inside the mini and run all my hardware.
Thanks in advance to any suggestions anyone has that might help.
* Asus Z270i Strix
* Intel i7 7700
