SFF.Network [SFF Network] SilverStone releases the NT09-115X low-profile CPU cooler
Today SilverStone has announced the NT09-115X, a 45mm tall CPU heatsink for Intel LGA 1156/1155/1150/1151 processors with a TDP of 65W or less. The heatsink itself is a fairly basic extruded aluminum affair like the stock heatsinks but instead with sturdy-looking spring-loaded screws to attach the heatsink to the motherboard instead of the sometimes frustrating plastic push-pins that Intel typically uses. The mounting screws thread into an included backplate that is intended to reduce motherboard warping.
Read more here.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
The fan is probably the most interesting thing here. If those holes are actually the same as for 80mm fans, it's the first 92mm fan I've ever seen do that.
7,411
Deepcool has had coolers like this for quite some time;
92mm fan, 80mm mounting, springs;
92mm fan, 80mm mount; Intel;
92mm fan, 80mm mount, AMD;
