SFF.Network [SFF Network] Samsung Announces the 960 PRO and 960 EVO
5,959
4,957
inb4 "labelgate", for when Samsung recalls the SSDs due to self-peeling stickers.
5,959
4,957
A comparison in real-life usage between a Samsung 960 EVO, Crucial MX300 and a WD Red Pro 4TB.
Look at that little stick fly ! Although they attribute the performance (in the title) to NVMe, while it's almost all because of PCIe speeds.
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
Very tempted to move to an all-SSD setup. Currently running an old 840 Evo 1TB and a 3TB 3.5" HDD. I could eliminate the on-the-fly SSD->HDD backup I do and set up a proper periodic backup to a NAS, which would mean a move to a 1TB m.2 (probably a 960 Evo) and a 2TB SSD (probably an MX300). I don't think I could quite manage with just the 1TB m.2 and reusing the existing 1TB SSD (just the offloaded Steam folder would fill most of it), and using an external drive feels like cheating and would slow things down even further. A pretty pricey sidegrade though, as much as I'd like to get rid of the last 3.5" HDD they still can't be beat for cost/GB.
::EDIT:mad:: Broke down and ordered one. Who knows when they'll actually ship though.
Stumbler
23
35
Sooo, the 960 pro 512gb has been on backorder forever so I canceled my order. Saw the 960 evo 1tb was in stock. Pretty happy with the decision.
Reactions: cmyk78
4,784
I really don't see the reason to go with the Pro over the EVO, because the vast majority of people who benefit from the extra capacity for the price of the EVO versus the performance of the Pro. Especially since the 960 EVO is still stupidly fast.
Reactions: Phuncz and Stumbler
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
Concur, even my old school Crucial MX300 NAND-based M.2 SSD is stupidly fast... though a NVMe would indeed be faster I highly doubt I would benefit from it nor would justifying a PRO in 90% of real world uses for anyone.
Soul_Est
1,536
1,928
Endurance. The Pros can usually withstand double the amount of writes that the EVOs can.
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
Do mere mortals (normal users) really ever enter this realm? I have never seen or known someone who has had SSD failure do over-writes... is this more common than I know?
Soul_Est
1,536
1,928
It used to be and depended a lot on the usage of the machine. Now, it is more a controller firmware issue and not a NAND flash issue. Hopefully the manufacturer got it right and we don't end up with another OCZ or Samsung debacle.
Reactions: ricochet
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
Not really, no.
When SSDs first came to the market, it was somewhat of a problem, but since then NAND cells have gotten a pretty large improvement to the maximum number of rewrites. Not to mention current drives are fairly well over-provisioned on flash cells (a 1TB drive has more capacity than that, but the controller only ever lets the PC see 1TB of it so it can remap dormant cells) for wear leveling, so endurance can be measured in severals of years under "normal" use.
5,959
4,957
Also, with increased capacity, the amount of "allowed" data written increases at the same rate. So the issue with 250GB and smaller drives in the past is now much reduced even more. Unless something is very wrong with your setup, like apps writing constantly to disk because of development not having a clue (for shame Spotify and Firefox !) and you don't fill your drive over 90% and keep re-writing data, you are way in the clear.
Most people concerned about SSD life span tend to forget that mechanical HDDs also have a limited life span, but you rarely see it coming. While the disks themselves could last a while, the mechanical parts often aren't specced for 10 years of operation.
5,959
4,957
Yep, endurance is looking pretty good. Enterprise is also loving SSDs, mentioning much beter reliability now that most technical reliability challenges like write endurance, retention and firmware issues have faded away. Sooner or later some drive will undoubtibly trigger another "Deathstar"-like scenario with firmware issues but that's about the worst thing I can think of. Except for shoddy production ofcourse but that is an issue the entire tech industry has.
4,784
Yeah, I've noticed lately that most webhosts offer an SSD storage option now, when just a few years ago that was fairly rare on the more affordable plans.
Reactions: Phuncz and ricochet
