Hello there!
My name is Tim and I'am part of a Hardware-Enthusiast and Modder Group in Germany.
I started doing ITX Hardware (mostly cases and cooler) Reviews a while ago and people constantly ask me if I can test part X in combination with Y in case Z
This thread should give an overview on what I currently own, what I plan for the future and which got reviewed already.
Feel free to post what hardware you would like to see in my tests!
I will update this post in the future and add more pictures soon
If you would like to suggest something how I do my reviews, post here ITX / SFF Case Contest - Your Suggestions
Cases
Chieftec BT-04B-U3
> 32,3cm x 13,5cm x 24,0cm
> Volume: ~10,5 Liter
> Datasheet / Manufacturer Page
LC-Power LC-1500Smi
> 25,8cm x 22,2cm x 21,3cm
> Volumen: 12,2 Liter
Kolink Rocket
> Tests need to be redone, cooler got recalled
Fractal Design Node 202
> Size (H x W x D): 37,7cm x 8,20cm x 33,0cm
> Volume: 10,2 litre
Fractal Design Node 304
> Size (W x H x D): 25,0cm x 21,0cm x 37,4cm
> Volume: 19,6 litre
Geeek A30 Mini
> Review planned
CPUs
Intel Core i5 6600K
> Delidded
> Primestable at 4,4Ghz - 1,25V
Intel Pentium G4560
> not delidded
AMD Ryzen 3 1200
> not delidded
> no Overclocking tested
Mainboards
Gigabyte GA-Z270N-WIFI (rev. 1.0)
> ITX / Overclockable / LGA 1151
Asus ROG Strix B250i Gaming
> ITX / Not Overclockable / LGA 1151
Asus PRIME A320M-K
> mATX / Not Overclockable / AM4
Cooler
Noctua NH-L9i
> Intel only / 37mm height / up to 95W TDP
Cryorig C1
> Intel + AMD / 74mm height / up to 140W TDP
Alpenföhn Black Ridge
> Intel + AMD / 47mm height / up to 95W TDP
GPUs
KFA² GTX 1050 Ti OC
> 181*97*33mm / No Power Plug required
SAPPHIRE PULSE ITX RX 570 4GD5
> 170*112*36mm / 1x 6 Pin Power
Zotac GTX 1060 Mini
> 174*111*36mm / 1x 6 Pin Power
PSUs
Chieftec SFX CSN-550C (3d printed an ATX bracket)
> CPU (4+4), 2x GPU (6+2) / 80+ Gold
Fractal Design Integra SFX 450W
> CPU (4+4), 2x GPU (6+2) / 80+ Bronze
Geeek Flex ATX Modular (Delta DPS-400AB)
Fans
2x Geeek DC Brushless
> 80*80*25mm / ? / ?
2x XF032 - XPF60S.W
> 60*60*15mm / 20,4 m³/h / 22 dBA
2x Cooltek Silent Fan 80
> 80*80*25mm / 43.1 m³/h / 20.3 dBA
Thats it, have a nice day!
~ Tim
Cases
Chieftec BT-04B-U3
> Volume: ~10,5 Liter
LC-Power LC-1500Smi
> Volumen: 12,2 Liter
Kolink Rocket
> Volume: 10,2 litre
> Volume: 19,6 litre
Geeek A30 Mini
> Review planned
CPUs
Intel Core i5 6600K
> Delidded
Intel Pentium G4560
> not delidded
AMD Ryzen 3 1200
> not delidded
Mainboards
Asus PRIME A320M-K
Cooler
Noctua NH-L9i
>> Noctua NH-L9i - Unboxing <<
Cryorig C1
>> Cryorig C1 - Unboxing <<
GPUs
KFA² GTX 1050 Ti OC
Zotac GTX 1060 Mini
PSUs
Fans
> 80*80*25mm / ? / ?
2x XF032 - XPF60S.W
~ Tim
