Power Supply Seasonic Prime Fanless TX-700 Impressions and disappointment
emrahkaracam
I purchased the Seasonic Prime Fanlsess TX-700 700W for a silence focused system in a Monsterlabo The First chassis. Since it is both fanless and open on all sides, it provides air passage. This device is 80+ Titanium certified and one of the most efficient ever seen in a power supply. At 230V voltage and 50% load, the efficiency reaches 97%. This is great value.
There is absolutely no heating in the device. Even though I can load 50% max with the hardware I have, there is no sign of overheating. No signs of reflected heat to the outer casing.
However, it has a flaw that destroys all its positive aspects. That's coil whine. A sound that can be heard easily from anywhere in the room in a high-pitched and quiet environment. This sound is heard in environments where low-speed fan noise is not heard. In this case, it's completely pointless to be fanless. If it did what it promised, I wouldn't care if similar products were sold for twice the price. In its current form, it is definitely not a product worth buying.
While it was going to be a great product, it was a complete fiasco.
I bought a TX-600 before and returned it for the same reason. The fact that the two products I bought sounded the same, makes me think that this sound is a side effect of increasing efficiency.
tinyitx
2,279
2,338
How unfortunate!!
Coil whine noise can be more annoying than fan noise.
On hindsight, if your hardware can push the TX-700 to only 50% (ie around 350W), maybe you should have bought in the first place the Silverstone NJ450-SXL Nightjar, which is a 450W unit 80+ Platinum. Platinum is just a grade lower than Titanium but has the same efficiency at 20% and 50% load and is only lower at 100% loading.
And, instead of having a perforated casing, it uses a completely sealed casing which acts as a massive heatsink. One selling point is that, due to a complete enclosure, coil whine noise (if any) can hardly escape.
Reactions: emrahkaracam
Mackan
309
161
I have the Fanless Titanium 600W. But it took 4 attempts to get a unit that had no coil whine. It is completely silent under any circumstances. So there is hope if you can deal with the annoyance of returning units.
I have also tried the Silverstone NJ450-SXL Nightjar, and it had an annoying coil whine when idle.
emrahkaracam
It is difficult to understand why they released the product with such a common coil whine problem. There is no point in not having a fan.
I can return the product, but I bought the last product from amazon. When there are other vendors, the cost of arriving in my country is very high. About 450€ for the Tx-700. 250€ when Amazon itself sells
Have you had a chance to try the px-500?
ignsvn
By Toutatis!
1,729
1,672
I feel ya there.
Personally, I'd rather choose a PSU with quiet fan rather than a fanless, but coil-whiny PSU.
Reactions: riba2233 and Phuncz
Mackan
309
161
I have not tried the PX-500. Since it is shorter (14cm only), and I don't need more than 500W anyways, it would be perfect. But the reason is related to the returns. I basically know I have to return X units to get a good one, and I can't be bothered again. It will literally waste months. And you also risk making your retailer angry, even if you provide a completely valid return reason, e.g. the coil whine. So sticking with the 600W for the forseeable future.
emrahkaracam
I've given up hope on the Tx series. I don't think I will try again. I'm almost sure that most have this problem.
The NJ700 (same tx-700) has the same noise. from 8:30
