Closed S4M Nvidia 3080 Ryzen 5800x S4Max-like Watercooled PC
Hi All,
I built a watercooled S4M that I'd like to test if it would be worth to sell instead of parting out.
Specs:
Ryzen 5800x
Nvidia 3080
Asus Strix B550i
32gb Teamgroup 3600mhz CL18 ram (lowest profile ram with heatsink that would work)
Power Suppy: Supermicro 804p 800W
Pico-psu - Jhack 200x
Corsair 140mm Radiator
Corsair XG7 Waterblock - Modded to remove shroud to fit with custom acrylic fitting
Alphacool 140mm 30mm Radiator (for external cooling as an option)
Noctua 140mm round fan (not pictured, but here is link Amazon.com: Noctua NF-P14r redux-1500 PWM, High Performance Cooling Fan, 4-Pin, 1500 RPM (140mm Grey) : Electronics)
loque PCIE 4.0 Riser
2tb Intel 660p
Festo 8mm Fittings
ADT-Link flat style hdmi and displayport extenders
Custom 3d Printed backplate for quick disconnect and display outs
Alphacool in-line water temp sensor
Alphacool DCLT 2600 pump v2 with Alphacool Eisstation 40 DC-LT Reservoir
Koolance QD2 for external radiator connections
Koolance Waterblock -low profile for CPU with 3D-printed retaining bracket
Case: S4M with Walnut faceplate (original black also provided)
I have ran this computer for 1.5 years but upgraded to a 4090 because I have a problem and moved into a dual rad meshlicious.
I'm thinking $1100 USD plus buyer pays actual shipping. Also, waiting on the latest ADT-Link hdmi cable extenders that have the rectifier chip for hdmi 2.1 output, so may need a couple weeks for that to arrive.
Let me know if interested.
ignsvn
By Toutatis!
1,729
1,672
I'm an air cooler guy but this is really good stuffs.
And if we take into account the blood, sweat & tears poured into this build, it's cheap.
Should be gone very quickly 😀
Gilles3000
240
244
It'd be cheap even without all the custom work, this thing is a bargain.
If I wasn't on a different continent, I'd pick it up in a heartbeat.
Reactions: ignsvn
Vaderator
67
155
Sold on eBay with different psu and case. Ping me if you are interested in the super micro psu (800w).
