Hello everyone. I'm excited to say that I've just preordered my S4M, HDPLEX 400 DC-ATX and HDPLEX 400 AC/DC. I'm planning to migrate my current build into this amazing case in order to reclaim some of the space in my sleeper berth.
After emailing Josh to verify that my build can definitely go into the case, and be brickless, I've been doing some looking around at options for connecting power. I have a good Hakko solder station, and I'm not afraid to use it, but I'd rather not modify the case, if possible.
I want to use a connector that has a ground, and I would like to have an EIF as well since the pc is ruining off of my truck's inverter. Not sure if the EIF is even a valid concern. Maybe someone who knows about such things could elucidate.
Here are the options I've come up with:
GX12-3:
Plan would be to chop off the C6 connector and solder the wires to the GX12 plug. Then chop the wires off of the C14 connector that comes with the brick and solder them to the GX12 socket. Not exactly sure how the EIF should be placed, but I'm guessing I would need to put it over the cable shielding?
C6:
Plan for this would essentially the same as above except that I wouldn't have to mod the power cable except for adding the EIF. As far as I can tell, this socket should fit on the case, but it's only rated for 2.5A, so I'm not sure that it would be the best solution.
This is my first time building with anything other than an ATX PSU, so I figured I'd ask for input before pulling the trigger. Any advice is welcome! I'm leaning towards the GX12-3, but I can't seem to find any better source for the connectorsso of anyone has a reputable source for those, or would be much appreciated!
GX12-3:
74271151 Wurth Elektronik | Mouser
74271151 Wurth Elektronik Ferrite Clamp On Cores STAR-TEC Snap Grey 100MHz 417Ohms datasheet, inventory, & pricing.
www.mouser.com
Monoprice Power Cord - NEMA 5-15P to IEC-320-C5, 18AWG, 7A/125V, 3-Prong, Black, 3ft - Monoprice.com
This is a 3‑conductor, grounded AC power cord designed for use with switched‑mode power supplies with the IEC 60320 C6 connector. It features a standard 3‑prong NEMA® 5‑15P
www.monoprice.com
C6:
6160.0001 Schurter Inc. | Connectors, Interconnects | DigiKey
Order today, ships today. 6160.0001 – Power Entry Connector Receptacle, Male Pins IEC 320-C6 Panel Mount, Flange from Schurter Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
www.mouser.com
www.monoprice.com
