Right angle pci thin itx motherboard - Biostar B360TH Ver. 6.x
owliwar
Lazer3D
Apr 7, 2017
586
1,082
hey guys, I was looking at motherboard dimmensions for my compatiblity list and found this gem
anyone got one of these? I've seen something similar but didnt new they were selling
Zackmd1
347
561
Where might one purchase said board? I cannot seem to find a retailer that lists it...
Arboreal
819
815
That's an impressive looking board. The power sockets look pretty serious, does that mean it can power a 75W card?
Reactions: owliwar
cleveland
455
240
Looks clean and well built, but the hole pattern indicates its not REALLY ITX (or Thin ITX, FWIM). Some cases could have troubles dealing with it...
Reactions: owliwar
Goatee
739
1,513
Ignore me, its in the title!
Looks like its slightly bigger then itx.
17.0cm x 19.305cm
Jello
376
163
I think PIO? Not sure about mounting pattern. Not that common outside of Asia from limited google searches.
I like that it would essentially eliminate the need for risers in a console style case. With an itx GPU like the MSI RTX 2070 being 42mm thick, would be cool to see a build with a 65w or 35w CPU in the board.
chx
553
282
These are used in cheaply built AIO in Chinese cyber cafes and I had one of these PIO boards for curiostiy and you will not mount in this anything but a custom case. Also with a common graphics card you can't achieve a really thin case with this either. The MSI Vortex G25 8RE is 43mm thick which is impossible to get from an off-the-shelf two slot GPU.
Reactions: owliwar
