Hello fellow SFFers.
I would like to present my current special project: the smallest. This is the smallest case I'll likely ever build and it'll be a bit of a magnus opus of everything I've done and learned after the last few years.
First, we'll lay out some ground rules:
1. The case must be straightforward and fairly easy to build in.
2. The case must support standard mobo, GPU, dimensions/specs.
3. A gaming PC is considered an ITX sized GPU and a 6 core processor at minimum.
The chassis? A 3D printed using SLS tech, "sandwich" style case with either acrylic or metal panels.
