Hello, want to add a moment switch to my x570. have a pig tail and a button but not sure how to wire it up. appreciate any help!
the pig tail has the dual wire for the power SW, and singles for the LED pos and neg
MOBO : ASUS ROG Crosshair VIII Impact AM4 AMD X570 SATA 6Gb/s Mini DTX AMD Motherboard
12mm White LED Light 2A NO-Momentary Push Button Switch Stainless :
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Mounting hole size:12mm, 4 Copper Pin Switch. White LED Light.
Operation type Momentary: Pressing the button ON, Release the button OFF.
Switch rating:2A/36VDC, LED can be ON all the time or only ON when switch is ON, depending on how you wire it.
Switch LED max voltage: 12V (when the voltage is higher than 3V, you need to add external resistor.)
Strong and durable, Degree of protection:waterproof IP67,IK08.
