Other Power and Reset button on AliExpress
stefan33
73
24
HI, please I'm looking for:
1-Power ON PC Button with LED
2-Rest PC Button
Please someone can help me to find something? I have this like exemple: But I dont understand if they can work as Power on or Reset... Thanks.
https://www.aliexpress.com/item/ELE...id=f2c45be5-c0a3-42b5-839a-f6304cdad3be&tpp=1
https://www.aliexpress.com/item/16m...id=f2c45be5-c0a3-42b5-839a-f6304cdad3be&tpp=1
https://www.aliexpress.com/item/5pc...32757211758.html?spm=2114.01010208.0.0.QTmmu5
https://www.aliexpress.com/item/Mom...id=fa64bc73-6566-473c-9266-d20168065303&tpp=1
https://www.aliexpress.com/item/GQ1...4.html?spm=2114.10010108.1000015.1.576vd9&s=p
I don't know nothing about voltage ecc....
I need only one Power Switch and one Reset.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
You need a Normally Open (NO) momentarily contact switch for both power and reset. Seems most of this linked would work. It's just a logic switch so voltage and amperage specs don't matter.
You don't need a reset switch nowadays. Just hold the power switch for 5 seconds.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
@Thehack is correct. You need to make sure the switch is specified as "Normally Open" and "momentary". If that's the case, you can use it as a power and/or reset switch.
You don't need to worry about voltage or current here, the current passing through the button is minuscule.
stefan33
73
24
thank you so much, but can you tell me exactly wich one I have to buy for power and wich one for reset? Thank you... More smaller are better is...
jtd871
1,166
851
The power button doubles as the reset button for ATX-compliant PSUs, if I haven't misunderstood. My pre-built (OEM) PCs have all worked like this, and I can't imagine that the retail PSUs wouldn't follow this pattern.
4,783
Both power and reset switches are momentary switches, the only difference is which motherboard header they're hooked to.
Reactions: CC Ricers
