Possible to fit an AC-DC psu in Streacom Fc8
Urgannagru
34
Hi been fortunate enough to get my mitts on a Fc8 relatively cheaply and tempted to try a 2400g build in it. I'm aware it reqrequi the use of a nano dc-atx psu but I'm wondering if it's possible to shoe horn in an AC-DC unit like hdplex'in order to get rid of an external brick.
Urgannagru
34
Cheers for the reply, aye that's what I'm planning on usingu glad to hear it should cope with the demands. Just not sure if there will be enough room round the motherboard to fit it, also I assume the ac-dc unit needs to be attached to a substantial bit of metal to help disperse the heat?
Thanks again.
KMPKT
3,382
5,936
Should cool passively through its enclosure actually. Airflow is obviously nice if you can orient your airflow in such a way.
