Selling Portable No-compromise Gaming PC
Payment Methods
  1. PayPal
Location
Albuquerque, NM-USA
Custom no compromise gaming PC. This is a SFF PC made from the NFC Skyreach Mini 4 case. The PC has a RTX 2070 Super Mini with DP1.4 output, i7-9700K and copper LP53 cooler with 3 Noctua fan options for cooling, and 64 Gb of DDR4 on an ITX AC ASrock Z390 chip set. 9700K is delided with liquid metal, and 2070S has liquid metal (with resistor protection) This system is entirely internally powered with a HDplex AC/DC/DC/DC 400w power solution. The PC is fitted into a pelican case with a lid mounted 4k-60Hz display and screen protector. The lockable case has padded tie downs, access hole for power button and air intake on bottom with laptop cooler installed to force convection cooling. The PC can be ran inside the case or externally if desired, just depends on chosen fan solution, undervolted tunes, and sound desired. All cables and mechanical wireless keyboard fit into case, while G502 fits into mouse holder on the side.
case can be unpacked and turned on to desktop in about a minute. SSDs/M.2 not included unless desired. Total weight is about 15 lbs. DM for questions. This is a perfect gaming solution for a frequent traveling gamer(fits in carry on), active LAN player, or designer.
Part List:
RTX 2070 Super Mini
i7-9700K Delided,
ASRock Motherboard (Z390 Phantom Gaming-ITX/AC)
HDPlex 400W AC-DC/DC-DC
Corsair Vengeance LPX 64GB (2 X 32GB) DDR4 3000 (PC4-24000) C16 1.35V Desktop Memory - Black
UPERFECT Truely 4K Computer Monitor, 15.6" IPS UHD 3840X2160 USB C Monitor[100% sRGB Wide Color Gamut], HDR FreeSync Speaker Type-C HDMI OTG VESA Portable Monitor for Laptop PC Phone, Stand Smart Case
G502 Wireless
DIERYA DK63 60% Keyboard with Dedicated Arrow Keys, Wireless Wired Mechanical Gaming Computer Keyboard True RGB LED Backlit Bluetooth 5.1 Programmable, N-Key Rollover for Windows and Mac- Red Switch
Accessories and Cables
Cooler LP53 x2
Noctua Fans 3x 92-125mm, 20-25mm
Skyreach 4 Mini case
jar2012
