GPU PNY RTX A2000 Graphics Card Initial Testing
Mark13
180
229
I received my A2000 6GB graphics card yesterday. Tiny, slick construction, quiet blower fan. Now this is SFF. The already installed drivers for my RTX 3060 worked without issue & the GPU's could be swapped back & forth. Both GPU's were run just as they come out of the box. I compared the A2000 to my PNY single fan 3060. As Blender allows integrated graphics to be used in addition to the GPU, I tested both GPU's alone & in combination with the integrated graphics of the 4750G Pro. I also ran the Blender classroom render in my main workstation using a 5700G CPU & an EVGA XC 3060Ti with render times of 1:43.61 (GPU only) and 1:37.07 (with integrated graphics).
Lazer 3D LZX-10 PC Case
Aorus B550 ITX MB; Ryzen 7 4750G; 32 GB Corsair LPX 3200 RAM; Metal block over NVMe drive not installed;
PNY RTX A2000 & RTX 3060 Graphics Cards – Self Regulated
Noctua L12 Ghost Edition - No bottom fan
Noctua NT-H1 Thermal Paste
Front Exhaust - No rear fan - Downdraft Cooler
Blender Classroom Render
Room Temp 21C;
Temp Sensor TZ10 read 16.8C on all test runs;
CPUID HWMonitor Readings: (GPU Max wattage reads out in % not watts on A2000)
Case Fans​
Front Exhaust Fan Only​
CPU Cooler​
Noctua L12 GE no bottom fan​
GPU​
PNY RTX A2000​
PNY RTX 3060​
PNY RTX A2000 & Integrated Graphics​
PNY RTX 3060 & Integrated Graphics​
Case Top Panel​
Fully Vented​
Fully Vented​
Fully Vented​
Fully Vented​
Case Front Panel​
10 Slots​
10 Slots​
10 Slots​
10 Slots​
CPU Cooler Fan​
Phanteks T30​
Phanteks T30​
Phanteks T30​
Phanteks T30​
Front Case Fan​
Arctic P14​
Arctic P14​
Arctic P14​
Arctic P14​
Rear Case Fan​
None​
None​
None​
None​
Temp Sensor 0 Max​
40​
40​
41​
39​
Temp Sensor 1 Max​
33​
34​
36​
36​
Temp Sensor 2 CPU Max​
49​
49​
69​
69​
Temp Sensor 3 PCI Max​
21​
21​
21​
21​
Temp Sensor 4 Max​
34​
34​
37​
37​
Temp Sensor 5 Max​
40​
39​
41​
39​
CPU Fan Max RPM​
1934​
2027​
2973​
2047​
Front Case Fan Max RPM​
1092​
1092​
1112​
1092​
Rear Case Fan Max RPM​
N/A​
N/A​
N/A​
N/A​
CPU Pkg Max Temp​
49.8​
52.3​
69.6​
69.8​
CPU Pkg Max Wattage​
30.57​
36.2​
83.25​
82.6​
NVMe Top 970 Evo+ Temp​
37​
40​
39​
39​
NVMe Bottom​
N/A​
N/A​
N/A​
N/A​
GPU Max Temp​
72.3​
70.6​
71.8​
68.6​
GPU Hot Spot Max Temp​
79.1​
81.9​
78.2​
80​
GPU Max Wattage​
107.42%​
140.58​
108.48%​
139.74​
GPU Fan Max RPM​
3646​
1614​
3566​
1447​
Blender Classroom Render Time​
03:06.80​
02:30.33​
02:36.90​
02:14.31​
Reactions: Tyrael and Phuncz
