PK39 build
cosmopock
Hi everyone its my second m-itx build i would like to show you
-Case PK39 from aliexpres
-Procesor ryzen 5 1600AF
-MOBO AorusX570 ITX
-GPU KFA2 GeForce RTX 2060 SUPER Elite 1-Click OC 8GB GDDR6
-PSU ENP-7660B
-Ram Klissre 2400mhz 2x8gb
-CPU Cooling NH L9a-AM4
-SSD Gigabyte 500gb M.2 PCIe Gen4 NVMe AORUS
In future im planing to change ram for somthing low profile to fit 120x15mm adapter and fan on cpu heatsink
Reactions: thelaughingman
thelaughingman
178
118
so from what I gather this PK39 is similar to the Velka 3 - does it have mounting for exhaust fan at the top also?
villu
Are you happy with the GPU? Temps and noise? I'm also considering this GPU, but I'm not sure this will be a reasonable upgrade from my 1070itx (especially considering price - KFA2 ~400€ vs 150-170€ I can salvage from my current 1070).
cosmopock
In Furmark on 100% load and defult settings its getting to 80C ,but if you tune the fans to run on 100% it will get 70C with automatic 1920Mhz using 1 click OC. Im pretty happy with this Gpu but its mutch louder then my Zotac 1070 ti mini. So the noise can be problem but the temps are realy good for a gpu whitch can fit in case under 3,9L
cosmopock
Update : I did mount new noctua 120mm fan NF-A12x15 on cpu but temperature is hotter by 10 degrees. Got back to my old 92mm fan hitting 75 degrees
