Opinions on this build and gear compatibility with NCase M1
erotavlas
30
Hi I'm trying to build a mini itx system into the NCase M1. CPU I chose is definite, not changing that.
Things I'm not sure about:
CPU cooler - not sure if its a good choice for the case - I already have it in my current i5 2500k system, so I was wondering if I could just make use of it and save the cost of a new cooler, i just need to get the mounting kit to adapt it to AMD
RAM - I think 3200 speed is enough can I do 3000? Should I worry about the size - i.e. how tall it is?
Video Card - This is a major unknown for me. First of all they are so expensive and there are so many variations its hard to choose. I think a RTX 2060 is the most I want to buy 6GB might be ok but I initially chose the ASUS Dual GeForce RTX™ 2060 OC edition 6GB GDDR6 and someone said that it sucks. I really don't want one of those mini itx cards with the smaller fans because they will be noisy. Any suggestions on this? I think low noise is secondary priority here after cost/performance.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($258.75 @ Vuugo)
CPU Cooler: Noctua NH-U9B SE2 37.86 CFM CPU Cooler (Purchased For $0.00)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard ($287.50 @ Vuugo)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 Memory ($169.99 @ Memory Express)
Storage: Western Digital Blue 1 TB M.2-2280 Solid State Drive ($119.99 @ Memory Express)
Video Card: Asus GeForce RTX 2060 SUPER 8 GB Turbo EVO Video Card ($555.50 @ Vuugo)
Case: NCASE M1 Mini ITX Tower Case ($300.00)
Power Supply: Corsair SF 600 W 80+ Gold Certified Fully Modular SFX Power Supply ($147.99 @ Vuugo)
Total: $1539.72
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2019-12-17 20:43 EST-0500
erotavlas
30
$1500 is the max I would spend.
Uses:
entry level machine learning
software development
photo editing
Leinel
21
If you don't have a problem with used parts, you can even get a 1080ti on Ebay for about 500€. Optimum Tech made some videos about graphic cards and compared them with his 1080 ti.
Reactions: DemLep
domiji
Nov 25, 2019
I would recommend you to swap out the X570 board for a B450 (Asus B450 I Gaming) and put the money in a faster memory kit with 3600 MHz. Your Ryzen CPU will benefit so much from higher ram frequencies and timings.
The WD SSD i would change to an ADATA XPG 8200 Pro for nearly the same price.
Normally i would suggest to go with a 5700XT but i dont know how warm this setup would be in the M1 case. 2060 Super is also a very good choice and nearly on 2070 performance-levels.
For the cooler i would go with a small 120mm AIO like a Corsair H60 or a small NZXT.
