Log Obsidian - Picture Frame Minimal Build
CroyAlore
23
108
Hello all, I've got another small build completed. The goal of this build was to make the cleanest, smallest, most simplistic build I could with this idea for a 'case' I've had in mind. I tested out a couple of things and ended up completing the build before I could get a work log going, so for this work log I'm posting the final product then posting some work log pictures later to show I built it.
Hardware:
[CPU]:
AMD Ryzen 7 3700X
[GPU]: GIGABYTE GTX 1650 4GB Low Profile
[MOBO]: Asus ROG Strix B550-I
[RAM]: CORSAIR Vengeance RGB Pro 16GB - 3200 C14
[NVMe]: Samsung 970 EVO Plus SSD 1TB
[PSU]: HDPLEX 160W DC-ATX
[CASE]: Custom 11x14 Picture Frame
[COOLER]: Noctua NH-L9a-AM4
Other:
[RISER]:
Phanteks 220mm GPU Riser
The theme for this build is solid black with a high contrast white. I hope you guys enjoy the build, just like with Pluto this build shouldn't have many updates and I'll probably just have one big update after this with worklog images and some more final images/ benchmarks. If you have any requests for images and benchmarks just ask I'd be more than happy to try to get them here.
Thanks all.
