I am not planning to use any GPU with this setup since i don't play much games but i do it sometime.
I will mostly installed windows VMs on a linux host.
Intel Core i9-10900 2.8 GHz 10-Core Processor
Motherboard: Asus ROG STRIX B460-I GAMING Mini ITX LGA 1200 Motherboard
Memory: Corsair Vengeance LPX 64 GB (2 x 32 GB) DDR4-3200 CL16
Storage PCIe: Crucial P1 1 TB M.2-2280 NVME Solid State Drive
Storage Sata : Kingston Q500 480 GB 2.5" Solid State Drive
case: NZXT H1
How will the thermals of the CPU affected without any GPU considering it is only 65 watt CPU for PL1 and around 224 watt for PL2
Also, what GPU you would suggest keeping the thermals in a good range. Right now the only thing that i can think of RTX 2060 because of its low power consumption 160 watts.
The latest 30 series of NVIDIA are too powerful for this case i think and it won't be good in the long run.
Also, i am thinking to buy the front panel replacing the glass panel like this one to reduce the thermals. Do you think its worth it or i am wasting money?
case: NZXT H1
