Hello Community , this is my First Post and my second SFF build in a NR200. I started with a alphacool Eisbaer LT240 and wanted to run the 5700XT Air cooled . My plans changed when i bought a very cheap used bykski waterblock. I tried to run the dual Loop setup of the one Solo Lt pump. I have read before that the pump is not strong enough for a dual Radiator setup with added GPU Block but i wanted to try it myself. After the first start and the first Benchmarks i noticed the GPU got realy hot and added a second pump reservoir combo from Alphacool. I also added a alphacool Backplate and thermalpads to the Back of the die ram and other components that get hot. After all the temps reach 97 Hotspot and around 78 global gpu after 10 minuts in heaven Benchmark. Seam Like this is a realy hot GPU . I would Love to hear about your opinion about the build and especially about the temperatures.
