Log NR200 - Dual Radiator Custom Loop (+6 drives)
viperguy212
Hey all,
I've been stalking this case since the initial leak and I'm happy to report that I've received my case as of 8/15 (US-NJ) and have started the build!
Parts List:
  • NR200
  • Corsair Sf750
  • Gigabtye B550 ITX
  • Ryzen 3600 (placeholder for Zen 3)
  • GTX 1080ti (placeholder for 3000 series)
  • 32GB Trident Gskill
  • WD750
  • Samsung 950 pro
  • 4 SATA SSDs
  • 2 Scythe Kaze Flex 120's (top)
Watercooling
  • HWL 240 GTS
  • XSPC TX240
  • Darkside PWM GT's 1850 (side)
  • Noctua Chromax slims (bottom)
  • EK DDC PWM 3.2 + Top
  • [secret sauce] 3D printed pump mount
  • Optimus Foundations AM4 cpu block
  • EK torque fittings
  • EK ZMT tubing
  • Kollance Quick disconnects for res/fill
Pics as of 8/16/20 - waiting on just a few more parts to arrive this week:
Stay tunned!
teodoro
109
77
I'm glad to hear this case actually shipped in the US. the amazon date kept shifting forward (and is now 'delivered by sept 9 - oct 6' for the nr200 non-p) with the TG version being 'unavailable.' any reason you're doing a side 240 instead of 280?
Butter
I'm looking to possibly build my next PC in the NR200 and wanted to know if you think/know if a 28mm thick radiator would fit on the bottom with a water cooled GPU?
Reactions: PixelatedScraps
PixelatedScraps
26
45
Hong Kong
I taped my slim 280mm EK Coolstream to the bottom panel of my NR200 with double sided black gaff tape. Works fine. I’ll be posting pics from that build soon...
