Parts needed:
1. Noctua NH-L9a or NH-L9i cooler
2. $9.50 Kaze-Jyu Slim 100mm fan
3. $0.40 silicon washer pack from Home Depot (optional)
4. Stock Noctua NH-L9 screws
Tools required:
Phillips screwdriver
The Kaze-Jyu slim fan is 12mm high instead of 14mm. The small silicon washers add a tiny bit of rise and also provide vibration dampening.
The fan blades will hang slightly over the stock heatsink providing steady cooling at 2000rpm.
The fan is slightly louder than the Noctua and because it hangs over you must make sure that there is clearance for the fan to mount. As a bonus, the fan is black so it matches more systems. The 100mm fan can be installed easily with no extra mounting gear thanks to the inclusion of 90/92mm mounting holes.
Tools required:
