Closed NFC S4 Mini Classic $250 shipped
Zuuk
60
88
What's done to the wrap around bezel? Hard to tell from the dark picture other than it seems to have skyslots on it. :)
VisualStim
431
211
I used a pneumatic zip saw and cut a rectangle piece out that was the same size that the chassis gpu opening. I took a little adhesive and put the slotted vent on the wrap. This allows you do use modified gpu shrouds so you didn’t have spend an extra $50 for that “acrylic lol 3D bezel”
slimydog
Watch out for this dude. If it looks sketch and smells sketch - also add in the privileged attitude...
VisualStim
431
211
i just explained it above. you are too stupid to understand. so fuck off you are too stupid to buy my case
7,745
@VisualStim Watch your attitude. Such remarks are in violation of our terms of service, namely personal attacks being prohibited. Also considering that you are trying to sell an item, aforementioned responses are likely to reduce your possible buyers across the board, and not just to the particular user(a) you have taken offense to.
Reactions: Rjk1617 and chx
